Closed
I just finished my build but now i hate my case any thoughts?
Last response: in Components
Please help me pick out a better case for my build.which is the range of 100- 150.
I am looking for looks and good management. I would like to have some room to expand. In ways like another video card
and hard drives.
(checK out my video posting to see my rig) http://youtu.be/igRyI3Ms3UM
This is the first time i have posted a video that requires me to talk so please be nice.
I have posted the details of the hardware in the build.
Thanks guys
Best solution
Power supply Master
You did very well for your budget. I would leave it alone until your next major upgrade. Alot of posts about transfer issues; "it worked fine until I transferred everything to my new case". On a low budget you really don't want to go with water cooling. At a certain point when overclocking, your rate of return (improved frame rates) is too low to justify the cost.
Thanks buddy for the comments. As far as water cooling goes i got the h80 as a open box item for 35.00. I took a gamble at it and it worked out really well no pump noise or anything wrong.
What do u think about the raven 3.
I really like that case although its a little over my budget.
Power supply Master
Unless you win the lottery, I wouldn't spend the money. My last two cases were $30 or less. For the price of the raven, you can get a nice video card. If you're a working stiff like I used to be (semi-retired) then I would search craigslist or other sources for someone else's mistake and make an offer. But it's nice to dream.
Related ressources
"Someone else's mistake" hahaha
this build was hell i wanted to enable IRST and man wat a challenge that is one a p8z68v-lx
mouse24 said:
the cable management in that video makes me want to cry
Maybe a case from the HAF series?
I wanted to get that but biggest mistake I made is took my wife to buy a case.
wife" its too scifi ( robot like)."
me " lets go home so i can beat u"
Ask the community
