Hello,
I have a surge protector with many plugs plugged into it. My computer uses a 1200W PSU, (yes it eats a lot of power) and recently I left my computer on for a while, it was downloading something, and when I went back to check on it it had shut down. I didn't think much of it and went to sleep.
Later my wife told me that all the power in the computer room only, power in the rest of the house was fine, had gone out. She checked the circuit box and said the switch for the computer room was in a strange position and she reset it.
The power is now working in my computer room but nothing happens when I switch on the computer. I tried different outlets on the wall and different power cords, I now need to try switching in my old power supply but will have to wait till later to find it. But the thing is that the on off switch on the power supply lights up depending on if the switch is on or off so maybe its not the power supply. If its the mobo I'm just gonna get a new computer.
My question is why did the power only go out of the computer room? Does it have to do with the fact that my pc is so power hungry (its a i7 960 overclocked to 4 ghz had to increase the voltage quite a bit, and has 2 gtx 480s) and it was plugged into 1 power surge protector/extension unit with so many other electrical devices? It was working fine for a while now. I know its most likely the psu or the mobo, I was just wondering other peoples opinions might be. Thanks.
