Solved
Join two linksys wireless routers together with ethernet cable
I bought a new linksys e2000 router and got it setup with thesoftware. My old router is a wrt400n and I want to set it up in the garage using a ethernet cable to extend the range of my home network. how do I do this?
6 answers Last reply Best Answer
More about join linksys wireless routers ethernet cable
  1. Best answer
    log into the router in the garage - connecting via network cable - disable the DHCP and change the LAN IP to 192.168.1.253
    then connect it to the main router by using one of the four LAN ports, NOT the WAN/Internet port
    I can't log into the router in the garage since I changed address to 192.168.2.1
    which I was told to do using earlier instructions on another forum what do I do now?
  3. I can't log into the router in the garage since I changed address to 192.168.2.1
  4. there should be a reset button on the back of the router, press it for 30+ sec. This will reset it to manufacturer default.
    only connect the router to the PC and set it up using the IP 192.168.1.1
    first setup the wireless security and save
    then turn off DHCP and change the LAN IP to 192.168.1.253 and save
    finally connect the router using one of the four LAN ports to the main router
    Thanks.
  6. Best answer selected by rlandry.
Configuration Wireless Router Linksys Ethernet Card Cable Routers Wireless Networking
