Z77 extreme4 atx 12v cable
Related ressources:
- ForumAsRock z77 Extreme4 -- I need your help! (New Build)
- ForumAsRock Z77 Extreme4 turning on problems
- ForumMelted the + 12V pin on ATX
- ForumCannot connect PSU to ATX 12V Power Connector
- ForumDoes the z77 extreme4 have a cpu power connector?
- ForumZ77 Extreme4 Build - Build Advice / Tips?
- ForumCrashing Z77 Extreme4
- ForumI think my AsRock z77 Extreme4 is not working, need help
- ForumAsrock z77 extreme4
- ForumAC'97 on z77 extreme4 ?
- ForumNew ASRock z77 Extreme4 - PCI-E Video Card(s) = Not detecting.
- ForumAsrock Z77 Extreme4 HELP!!!!
- ForumASRock Z77 Extreme4 OR Z68 Extreme4 Gen3
- ForumNeed replacement Z77 micro- ATX mobo
- ForumMB power supply using ATX 12V plug?
- ForumDo I have a faulty ATX 12V conection?
- ForumExtreme4 8 pin atx 12v
- ForumPlease help! struggling to select build components for micro atx
- ForumHelp updating BIOS
- More resources
Read discussions in other Motherboards categories
I've located the 12v atx power header on the mobo but which cable from the psu goes into it? The only ones I think could work are two 4 pin connecters (2x2 dimensions per connector right?)
good luck to you too
