Closed Solved
Help with the Z77 Extreme4 and trying to go wireless
Hi. I built my first rig using the Z77 Extreme 4. Unfortunately, I overlooked that it only has a port to directly connect the LAN cable for the internet. I guess I made a newbie mistake there.
I was talked into picking up a Netgear N900 Wireless Dual Band USB adapter from a salesperson at my local electronics store. That device, whenever I try to install the software, does not recognize my OS (Windows 8). I have gone to the Netgear site and they seem to be having problems of their own when it comes to downloading any sort of updates. I see the windows 8 updated, but I am unable to download anything.
Is there another option to hooking my pc into my wireless? Your suggestions are greatly appreciated.
2 answers Last reply Best Answer
More about help extreme4 wireless
  1. Best answer
    No. A different adapter that supports Windows 8 ?
  2. Best answer selected by Camaro67.
ASRock Wireless Motherboards
