Solved
Help on building small pc for kids?
Last response: in Systems
Hey i'm a gamer and premade my pc. But now I want to build a budget pc for my kids to learn and play learning games on, without messing up my pc. I was thinking a small mini computer that is easy to move around and can play movies as well. My son is 4 so he needs to learn how to use a keyboard and mouse stuff like that. Any suggestions on combo/deals?
I'm not a newb I'm rocking
p8p67 pro
H70
i5 2500k
tx850watt corsair
corsair 650D
GTX560
8gig vengeance
More about : building small kids
If you want a very cheap build:
MOBO: Gigabyte m68mt-s2p
CPU: AMD Semprom 145
RAM: Kingston DDR3 2GB (1066)
VGA: OnBoard
PSU: 400W is more than enough
CASE: whatever you want
HDD: whatever you want
OPTICAL:whatever you want
Related ressources
Best solution
Homebuilt system Expert
Most kids educational games could probably be pulled off with integrated graphics (reading rabbit and so forth), but I would splurge for some kind of dedicated card so as he gets older he can play some more advanced games like Civ 5 or whatever.
I'd suggest an intel 1155 so you could give him your 2500k if you upgraded to Ivy Bridge. I'm also going for cheap since a 4-year old kid will not appreciate the difference between a $300 build and a $1000 build.
(All prices from newegg.com)
CPU: Intel Celeron G530 - $56.99
MoBo: ASRock H61M-VS - $53.99
RAM: 4GB (single stick so you can expand later) DDR3 1333 1.5V CAS 9 ~$23
PSU: CORSAIR CX430 V2 - $20 after all rebates and discounts
GPU: PowerColor AX5570 1GBD3-H - $39.99 after rebates
HDD: Seagate Barracuda ST3160316AS 160GB 7200 RPM 8MB Cache SATA 6.0Gb/s 3.5 - $34.99
Optical: whatever - $20
Case: APEX TX-381-C (has a handle, but you could pick something else) - $32.98
Total - $311.94 after rebates including shipping.
You still need an OS and Windows 7 Home Edition OEM costs ~$99
This could play Civ 5 and should handle any educational game you throw at it. You could swap the case for anything you want, that one just seemed convenient and cheap.
Ask the community
