Hey guys, I'm going to be building a new system as my current one is incredibly out of date. Whilst I have done the occasional upgrade to my old system, I have never actually built a system from scratch before, so I could use a little advice.
I'm going to be using this rig for gaming (mostly I'm building it for Skyrim) however I'm not looking for an incredibly powerful top of the range machine.
So far the parts I have selected are:
Motherboard:
Gigabyte Z68AP-D3
http://www.dinopc.com/shop/pc/viewPrd.asp?idproduct=1167
PSU:
Corsair Builder Series CX 600W V2 '80 Plus' Power Supply http://www.overclockers.co.uk/showproduct.php?prodid=CA-048-CS&groupid=701&catid=123&subcat=1084
Graphics card:
NVIDIA GeForce GTX 560 1GB http://www.dinopc.com/shop/pc/viewPrd.asp?idproduct=1084
RAM:
4.0GB Corsair DDR3 1600mhz XMS3 (2x 2GB)
Processor:
Intel Core i5 2500K http://www.dinopc.com/shop/pc/viewPrd.asp?idproduct=995
I'm going to be using my current hard drive which already has Windows 7 on it. I'm going to be following this guide which should (hopefully) allow me to use the same hard drive. http://www.sevenforums.com/tutorials/135077-windows-7-installation-transfer-new-computer.html
My current case is also fine.
So I guess my questions will be
1) Is all this compatible which each other?
2) Do any parts need to be changed?
3) This all works out to around £500, could I replace any parts for a cheaper alternative without my machine suffering too much?
Thanks a bunch!
Motherboard:
Gigabyte Z68AP-D3
PSU:
Graphics card:
RAM:
Processor:
Thanks a bunch!
