Where do i plug in power led and power sw
i think im finally going to have my desktop up and running today
but....there are cables i still dont know where to plug in
some of them have no holes for the prongs so im hoping that will help me determine where to plug them into the motherboard
im really not sure where these power sw and power led cables need to be placed, though
those are the 3 other cables i dont know where they go. the one on the far right says usb, the other two are unmarked
thats a total of 5 cables that have me scratching my head
6 answers Last reply
More about where plug power power
  1. you plug them into the motherboard header located on the bottom right corner
    header label information can be found in the motherboard's manual
  2. what about the 3 in the picture?
  3. It would help to know what motherboard and case you have to give specific instructions. The one labeled USB goes to the onboard USB sockets. Be careful. If your case and MB have Firewire connectors, keep in mind that they are keyed the same as USB and mixing them up can damage the motherboard. The narrow connector looks like audio. Many cases include both HD audio and legacy audio. Modern MB's use HD audio, so if the HD is already connected, then the legacy connector does not get used. Just tuck it out of the way.
  4. Don't you have documentation for the MB?
  5. Those look like USB and audio headers, and possibly a PC speaker
    Your case likely has a small manual as well, and should explain the pieces.
    Believe it or not, the instructions are useful.
  6. yeah the motherboard is:
    ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
    the case is an old gateway is an old gt5404
    i just hope the asus manual is better than the biostar one. for the price difference it should be.
Motherboards Cable LED Monitor Power Product
