Solved
Power Supply Question, last obstacle in my build (HELP)
Last response: in Systems
Which Power Supply would you get, $ not an option?
OCZ ZX Series 850W Fully-Modular 80PLUS Gold High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
Thermaltake Toughpower Grand TPG-850M 850W ATX 12V v2.3 & SSI EPS 12V v2.92 SLI Certified CrossFire Certified 80 PLUS GOLD Certified Active PFC Power Supply
System set up.
COOLER MASTER HAF 932 Advanced
I7-2600k
COOLER MASTER Hyper 212 EVO
GIGABYTE GA-Z68XP-UD3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
2 XFX HD-697A-CNDC Radeon HD 6970 2GB in crossfire mode.
ASUS 24X DVD Burner
& a blue ray player, burner I will be installing later in the near future
& a 240gb ssd, burner I will be installing later in the near future
& sound card, burner I will be installing later in the near future
& bluetooth card, burner I will be installing later in the near future
Related ressources
This OCX ZX series 1000 gets a 9.5 Performance rating
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
This OCX Z series gets an 8.5
This Toughpower Grand gets a 9.0
This Toughpower Grand gets a 7.0
Personally I lean to the Seasonic X Series, Antec SG / CP series, and Corsair HX series at 850 watts (other sizes of HX not so hot) ..... posted closest ones in size to where I couldn't find an 850 watter
Seasonic X-750 (9.5)
Seasonic X-760 (9.5)
Seasonic X-650 (10.0)
Antec SG-850 (10.0)
Antec CP-850 (10.0) - steal at $115 but ya need compatible case)
Antec HCP-850 (9.0)
Antec HCG-900 (9.5)
Corsair AX850 (9.5)
Corsair HX850 (10.0)
Corsair TX850 (9.5)
Corsair TX850 V2 (9.5)
Ask the community
