RUN entry problem in XP Pro SP1
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Greetings:
I've been having a problem with some programs that automatically startup
when XP starts. A folder opens up on my desktop instead of the program
executing.
Based on info I found from Doug and Kelly I determined that this was due to
the filename/foldername in the RUN entry not being enclosed in quotes. In
all cases the names have spaces in them. Adding quotes solved my problem.
But this begs the question. Should my system have automatically added the
quotes to the RUN entry in the first place when I installed the application?
Or should the application installer have done this? The author of one of
the programs told me that my system should be doing this not his installer
Since this problem is fairly recent I am assuming that something on my
system is broke. I never had to manually add quotes to these kinds of
entries before.
If things are indeed broke, how can I fix it?
Thanks.
Streetwolf
"Klaatu barada nikto!"
G
Guest
Guest
Its not your system, its the installer software that creates it. If an entry needs to be in quotes, it needs to be done by the install software.
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
"Streetwolf" <streetwolf at 7twenty1 dot com> wrote in message news:410e3335$0$20941$9a6e19ea@news.newshosting.com...
> Greetings:
> executing.
> entries before.
> Thanks.
> Streetwolf
