Hi all.
I need help choosing a power supply for a new build I am working on. Looking to do an mATX build in a small case.
CPU: Intel Core i5-2500K
MOBO: ASUS Maximus IV Gene-Z LGA 1155 Intel Z68
RAM: G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
GPU: EVGA GeForce GTX 590 (Fermi) Classified 3072MB 768-bit GDDR5
CPU Cooler: Corsair H60
or
Corsair H100 (If I can make it fit in the case)
SSD: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
And of course I will have an optical drive as well. And it will have 3 fans with the H60 or 4 fans with the H100.
My main question is will 650w be enough? Or will I perhaps need a 750w or even 850w? I used the Corsair AX750 for my current build and am planning on using the same series of PSU.
or
