Closed
Switching from sound card to integrated?
Last response: in Components
January 21, 2012 7:34:28 PM
Is there a way I can switch between my headset that is connected to my sound card and my speakers that are connected to my integrated sound without having to unplug anything?
January 21, 2012 7:41:17 PM
nope. usually integrated sound is on your motherboard.
Score
Best solution
January 21, 2012 7:54:47 PM
Get a set of speakers that has a headset/headphone plug and keep using your sound card.
They only have headphone out, so you would still need to keep your mic plugged in to your sound card.
January 27, 2012 10:59:26 PM
Ahhhh, thanks. But my headset has the headphone and microphone plug tied really close to each other, so I probably would need to find speakers with both plugs, right?
Score
January 27, 2012 11:27:19 PM
I don't get it!
Most people that use discrete soundcards aren't using the onboard sound(disabled in bios).
Most decent soundcards have a front panel header = use the case front inputs for HP & MIC.
Score
February 11, 2012 5:14:06 PM
Best answer selected by retox.
Score
February 11, 2012 9:46:30 PM
This topic has been closed by Mousemonkey
Score
