Problem whit my pc turning on and off
Hello i am here to ask for help
this is the problem
today i turned my pc on to use it but it gave no signal to the screen then i just waited but no result
then i tryed to hold the button on front to turn it OFF but it does not work the pc stay's ON
the only way to turn it ON if by pushing the power supply turn on/off switch
http://0.tqn.com/d/compreviews/1/0/V/2/DIY-PSU11.jpg
wen i turn if off and then on [power supply turn on/off switch]it turns on automatically whit out me pushing the front button to turn it on
and gives no signal or anything
More about : problem whit turning
Motherboard Expert
Power supply Expert
Check the power button switch on the case with a digital volt meter using the ohms scale to see if it is working properly , if it works then it could be power supply or motherboard. I would use a known good power supply to see if that solves the problem.
Ask the community
