Closed Solved
Nzxt zero 2 cable management
i have the nzxt zero 2 case and i was wondering if anyone can give me some tips on better cable management. i think i have been able to do a decent job since this was my first build. here are some pics and all criticism is welcome.
" class="img lazy">
" class="img lazy">
" class="img lazy">
" class="img lazy">
16 answers Last reply Best Answer
More about nzxt cable management
  1. Christ on a bike!
    Now heres a challenge hehe,
    Only on my phone atm so sorry for short answer,
    First thing is flip the hdd around so the sata and power feed from the back,
    But I also notice that the rear panel in those pics is actually the cases side panel,
    You have very little room to play with,
    If you are near Notts in the Uk, bring it to me and I'll do what I can hehe
    If not I'll throw some ideas up when I get to a pc
    Moto
  2. Motopsychojdn said:
    Christ on a bike!
    Moto
    yea im in the usa. i cant flip the hdd since that rear part of the case cannot be removed. i cant even fit cables through the holes.
    thanks for the help though
  3. You need to remove the front panel to insert the HDD's, DVD. Just pull on one side of the front case and you should be able to remove it. Most are attached by integral plastic clips attached to the fron pane, often called bezel.
    I just looked at a review on that case. The upper front panel is held by magnets and swings open to the right.
  4. can't comment on the wiring in that case but the CPU heatsink is definitely facing the wrong way
  5. sticky cable tie bases, and clamp all of the cables to the back wall of the case. Where you have to bring cables to the front, do it where metal is blocking airflow anyway. on i39, the only place I see where you are causing airflow issues, is on the right hand edge of the mobo, actually it looks quite clean other than that, messy but clean for air.
    Having said that you are remarkably lacking on intake fans by the looks of it, any 'issues' that you have a more likeky to be because of this than because of cables getting the way, looks like you have 3 exhausts, 2 larger and 1 smaller, 120's and 80's?
    the cpu cooler only mounts on amd processors north to south. on intel it mounts east to west. i heard there was a bracket that would allow me to mount it east to west but i havent had any luck finding it.
    Quote:
    13thmonkey
    i have 4 120 mm side case fans also that are intakes. and yea the 3 exhausts are 2 120mm and 1 80mm
  7. quite frankly I would not use that cooler as its only average and arctic cooling designed the bracket wrong. espcially with that case having such a small top exhaust fan. I suppose with those side intakes between it and the GPU, and one exhaust fan above it it may be ok, but it looks like all your CPU heat is gonna shoot straight into your PSU. And the hotter it gets the faster its fan will go and the more heat it will suck in.
    yea i was thinking about replacing it. now they have released this cooler http://www.arctic.ac/en/p/cooling/cpu/473/freezer-a30.html?c=2181 . as you can see it mounts east and west on amd processors. im going to wait for reviews before i buy it though. you have any suggestions to any other coolers that are good for an amd phenom 2 965?
  9. Best answer
    I'd be getting the drill and dremel out for that case, you can cut holes where the provided ones aren't enough for connectors to fit through, or remove the plugs and re-attach after feeding the cables through, either works
    You have a floppy drivebay above the hdd cage? use that to tuck wires into as well as the unused areas where the optical drives are
    but for cablef free in this case its going to take some serious thinking and a bit of modding I reckon,
    it all depends how far you want to go with it but you can as mentioned get blocks to zip tie them to out the way at the back, they'll be visible but not blocking airflow
    Moto
    Moto
    damn i was afraid of that. i never used a dremel before so i dont want to take the chance and butcher my case. ill keep at it though and by some sticky zip ties and work it out some more. i probably should have went with a modular psu for this case but oh well.
  11. No probs man, we live we learn :P
    My other halfs case was a similar nightmare
    http://www.tomshardware.co.uk/forum/forum2.php?config=tomshardwareuk.inc&cat=13&post=287494&page=2&p=1&sondage=0&owntopic=1&trash=0&trash_post=0&print=0&numreponse=0&quote_only=0&new=0&nojs=0
    give me a pm if you ever get the urge and a dremel mate,
    Moto
    Moto
    I love that you are such a diy guy. I will ask you if I ever need help modding my case :)
  13. No sweat man :-)
    I'm always happy to help out
    And ty for the compliment
    Moto
  14. I have an ultra m923 and your cable situation is about like mine, I do have one advantage though my psu mounts at the bottom, but your case appears roomy enough so atleast your getting some airflow and not everything crammed together. My setup is a little worse b/c I have 2 ssd's and 3 mechanical hdd's in there as well.
  15. Best answer selected by lw3.
  16. This topic has been closed by Mousemonkey
Power Supplies Management Cable Components
