hi,
having a problem! i have a 1000watt psu, but the thing is so loud! it has an 80mm fan that is the problem! i was going to install a quiter 80mm fan, but from what ive read even if i did it would still sound the same?
so i decided to go for a new psu, i dont need a 1000watt to power my system ( q6600 quad core cpu, geforce 560ti 2g graphics card, xfi soundcard).
i was informed a 750watt would do the job!
i bought said 750watt psu, installed no problem untill i realised it only had a 4 pin and 24 pin power connector ( i have 24 and 8 pin)
but i did read you could still run with a 4 pin in an 8 pin connector!
computer ran ok for about 15 min then strange things happened! first it started to freeze, no error message, just freeze! then my monitor would go blank put power still on! i could not switch monitor off!?
i had to unplug montor all the time! then plug it back in. the thing is my monitor is not connected to my pc, it goes to my adapter ( same one pc power cable plugged into).
750watt psu should be ok for my rig as i was advised!? do i need a 8 pin adapter? why does the monitor do that strange thing?
could anyone shine any light on my problem?
regards
regards
