Closed Solved
Mice problems
hey guys,
i am having a problem with my laptop not being able to see mice on my laptop. i am using a ball mouse i got with my dell desktop. it works but when i plug it in my laptop it does not see it. it use to be able but something happens and i had to wipe my laptop and reinstall windows. when i plug it in it says usb device not recognized. when i go into hardware it says unknown device and it doesn't work so i don't know what to do i went all over forms and i could not find any thing that was helpful. so please help me.
7 answers Last reply Best Answer
More about mice problems
  1. It sounds like you need a driver for that mouse. You can Google the name of your mouse followed by the model number and the word driver.
    Something like this: "genius mouse 454-xyz driver"
  2. i cant find one for my mouse mouse/m-uk del3 thats it
  3. That seems to be one of the old Dell/Logitech mice. If the laptop has Windows 7 on it, i doubt you will find a driver for the mouse.
    Windows 7 uses a different type of driver than XP, so a lot of the old XP hardware will not work.
    I do not know about your locale, but where I live you can get good new mice for $10 and under.
  4. i have xp on it
  5. Best answer
    did you try dell with you service tag to get the driver http://www.dell.com/support/drivers/ca/en/cadhs1?c=ca&l=en&s=dhs&~ck=mn if this is not working then you need another mouse
  6. Best answer selected by wanger212.
  7. This topic has been closed by Mousemonkey
Laptops Mice Components
