PC wireless to Router hard-wired to Printer
Hello,
I have XP(HE) SP3 wireless to NetGear WPN824 and a Laser Printer connected by a ethernet cable to the router.
The PC recognises the network but cannot find the printer.
Do I have the correct cable (it is black); how do I tell if this set up needs a different ethernet cable; what is crossover, etc and how do I tell one from the other?
4 answers Last reply
More about wireless router hard wired printer
  1. did you configure the printer's IP settings?
    Thanks for your reply -
    No, I don't know how.
    The printout from the Dell 1320c has details:
    Network
    Firmware Version 8.83
    MAC Address 08:00:37:75:35:4a
    Ethernet Settings 100Base Full(Auto)
    TCP/IP
    Get IP Address AutoIP
    IP Address 192.168. 1. 2
    Subnet Mask 255.255.255. 0
    Gateway Address 192.168. 1. 1
    Status Ready
    plus some other stuff about LPD, Port9100, FTP, SNMP, E-Mail Alert, EWS and IP Filter...
    I do not understand much but I can follow step by step instructions in simple terms.
    Hope to hear more,
    Regards,
    D :o
  3. Add Printer
    choose Local Printer but do not Autodetect
    choose Create a new port and select Standard TCP/IP Port
    enter the IP address 192.168.1.2
    install drivers either from CD or via Windows Update
  4. If Emeralds method does not work, try this: Click start, then run. Type cmd and press enter. In the prompt type net use 192.168.1.2 and press enter. See if that works, don't count on it though.
Routers Wireless Ethernet Card Cable Printers Networking
