What fans are better than the corsair fans that come with the h80?
Does anyone know the cfm of the fans that come with the h80? Are there any fans that you guys are running that help with push/pull in overclocking?
6 answers Last reply
More about what fans corsair fans
  1. fan speed is 1300 to 2500rpm, cfm 46-92cfm, and dba is 22-39
  2. If by better you mean quiet, check out the Antec Tri-cool. They have a 3 speed switch and even at high speed are relatively quiet. They are also available with or without various color leds.
  3. What about the cooler master sickle flow fans?
  4. I'm using a couple of Nexus D12SL
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835610006
    I've set the pump on low; not as silent as a high quality air solution but temps are great. The stock fans on the H80 are shameful...
  5. I'm a massive fan of Scythe fans. If you can get hold of the GentleTyphoon fans they are well worth the money, good air flow and very quiet.
  6. They are also available with or without various color leds.
Power Supplies Overclocking Corsair Components Product
