Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Power Supply Blowing Fuse
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Power Supply Blowing Fuse
Best answer from AdrianPerry.
I bought 2 new power supplies for 2 computers. One is my own, one is one I built for someone else. After doing a lot of process of elimination I found that my power supply was bad, or so I thought. Basically, after running the computer for awhile, and restarting, the PSU would blow out the fuse in my room. I'd reset it, and go to turn it back on, and it would blow again. I switched it out with a different PSU, the other new one. Same thing, blown fuse. Now, here's the kicker. I have a PSU tester. If I use that, BOTH PSU's are good. I found somewhere where the new PSU's send an arc message or something to the fuse box causing it to blow. Apparently the new PSU's are the only ones to do that to the fuses in my home. It seems homes built between 2002 and 2005 might have these fuses.
My question is, do I attempt to upgrade my fuse box, or do I return the PSU and tell them it's faulty?
BTW, PSU 1 is OCZ 600W Modular, PSU 2 is Raidmax 1000W Modular
Thanks in advance!
Reply to stryker617
The chance of 2 PSU's blowing is really really slim. This would suggest its your wall sockets causing the issue.
Using a surge protection plug might be a wise first move before you dive into spending more money on a new fuse box ect.
------------------------------ ~i5-2500k @ 4.0GHz w/ Freezer 13
~8GB 1600MHz Vengeance RAM
~ASUS P8Z68-v PRO
~Gigabyte GTX 560Ti @ 900MHz
Reply to AdrianPerry
If you have the means to upgrade your fuse box, I would do that. If you are using actual fuses, you should probable upgrade to breakers. Have an electrician do it of course.
Oh, and the Raidmax probably isn't the best psu you can get your hands on. For the future you should look for a better unit. The OCZ is the better of the two.
Reply to totalknowledge
It's not the wall sockets. Tested 3 different ones and all blew. The ones tested are located in the bedrooms. The ones located in the kitchen area or living room work fine with the PSU. And it is a breaker box. Sorry, I'm just used to calling it a fuse box since that is what I had at my older house.
I know raidmax isn't the best PSU. It was cheap, and is modular. If I had the cash, I'd go with a Corsair modular instead. But for under $100 for 1000W it seemed worth the risk.
The OCZ's I've had before seem to work fine. I'm using a Corsair 850 as of now and it works great, I just hate that it's not modular. I also have a multiple Coolmax PSU's, and have had quite a few others.
Reply to stryker617
Best answer
It sounds like you've already narrowed down the issue to the breaker box. My suggestion would be to replace this, cost depending of course, if its going to resolve the issue. Your more into the realm of electronics now rather than computing so I don't have much more to offer :(
~ASUS P8Z68-v PRO
Yeah, I kinda figured that's where it was headed. I did connect the PSU to a UPS. Turned on the PSU, and it ran, but it blew the fuse again, lol. I guess I'm just not meant to have that much power in one room. Thanks though!
Reply to stryker617
OH PLEASE!
The fuse is blowing, There's A SHORT CIRCUIT!
Replace the fuse panel? Good grief....who taught you guys how to troubleshoot?
99% chance the motherboard has dead short. Replace the motherboard, CPU, or whatever else is shorted. It's NOT the fuse box.
The hardware of the computer is SHORTED. Get it???
------------------------------ My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
Reply to soundguruman
The system worked when the OP tried the build in a different section of his house though (which is quite likely to be on a different circuit breaker)? Dumb luck that it didn't short when he tried this? :s
Message edited by AdrianPerry on 01-23-2012 at 04:27:58 PM
~ASUS P8Z68-v PRO
A short circuit on the motherboard would cause, or should cause, the over protection on the psu to trip, not the fuse box for the house. If the fuse box for the house is tripping he has a deeper problem than what the computer is causing.
First question: Did you try using a different circuit to connect the PC? Its possible that the circuit you are on is simply drawing too much power once the PC is turned on, causing the breaker to trip. Thats the most likely explanation.
Reply to gamerk316
It is not a short anywhere. I replaced the motherboard because I thought that too. Even booted up without a CPU. I had barebones on everything. It is 100% the circuit breaker. Arc Fault Circuit Breaker is what the issue it. Something with the switch itself is causing the blow outs. If it was a short in the motherboard, the known working PSU wouldn't of worked in the computer. I also did this with and without a UPS. All kept blowing. Now, if I connect to a outlet that is not connected to an Arc Fault Circuit Breaker, it does not blow out the fuse.
Trust me, I can troubleshoot. I've been building computers for years and always seem to end up with the issues that no one ever has, lol.
Reply to stryker617
No issues with power draw. When it did work, the PSU was drawing 100W start up, and around 47-50W while idle in windows. At first I thought it was Ubuntu that was causing my problems because running windows it would work great. As soon and I installed Ubuntu using Wubi and it restarted, the fuse would blow. That was another issue I had as well though. It ended up being Ubuntu not liking the GTX 550 I had. Fixed that with a ATI 5770 though.
Reply to stryker617
He already stated that it works fine in the Kitchen and living room work fine. It could be that the bedroom breakers are stretched over too many outlets, or that the wrong size breaker was installed. A qualified electrician would be able to determine which one. It could be as simple as unplugging a wall AC unit, or space heater, or it could be a beefier breaker would work.
eta: it could also be a bad breaker, or faulty wiring in the bed rooms. If the ground wires are not correctly connected it could be causing the issue. Or there could be a short in a different appliance that isn't quite tripping the breaker without the added load of the computer.
Message edited by totalknowledge on 01-23-2012 at 04:49:03 PM
Here is a link, random one I found, of someone else having around the same issue I am having with the AFCI breakers.
http://ask.metafilter.com/86678/Do [...] puter-more
I hope links are OK here. Sorry if they're not.
Reply to stryker617
Have you tried removing all other items from the circuit and running it? Is the circuit also running any lighting, or other parts of the house not outlet related?
In my room alone, there is a DVD player, a UPS and a wall charger plugged in. I had another computer connected, but shut that down along with a printer and an external hard drive. I was also using an outlet with nothing connected to it. I also tried 2 other outlets as well.
Reply to stryker617
Are all of the outlets three pronged outlets? Have you checked the outlets with one of these? And have you tried it with everything unplugged but the one computer?
http://ktoolconnection2.amazonwebs [...] GYBFAE.htm
*I am not sure I would keep trying things as the electricity shutting off on your computer could damage it.*
Message edited by totalknowledge on 01-23-2012 at 05:07:32 PM
Lol, I think I got this to drag on too long. All plugs are 3 pronged. I shouldn't need everything unplugged to get this to turn on. I have 4 PSU's that work. 2 that I used on the MB that I thought was faulty, and used on the other MB I had to go out and buy.
There is only 1 solution here after all the troubleshooting I did and it's the AFCI breaker in the breaker box. The outlets that work fine do not have those breakers, that's why it doesn't blow. Also, I had a Kill-A-Watt meter to check the wattage and amperage to be sure that it really isn't drawing too much power. I know it's not 100% accurate, but it's a good guess.
Thank you though for the input. This is just one of those weird occurrences that no matter what you fix or replace, it's not the computers fault here.
Reply to stryker617
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1931 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 8 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
