Old P4 2.4 to build into FreeNAS or upgrade current system?
Last response: in Systems
Hi Everybody...
I recently built myself a decent gaming rig about 6 mos. ago. Now I have this old Dinosaur Pentium 4 2.4gz lying around and I can't bring myself to just throw it away and I don't think it's worth anything really to anyone else.
I want to rip my two hundred some cd's onto a pc, but don't want to fill my 750 gig hard drive on my new build. I was thinking of turning the dinosaur into a FreeNAS system and modding the case with some cool stuff.
The old build only has a PATA 35 gig hard drive in it, so I think all I would need is a hard drive controller card and some hard drives right?
Or Should I just invest in an external HD or something like that on my new rig?
Old pc has a p4 2.4 proc, Biostar mobo that doesn't even have a pci express slot its so old, 1 gig ddr133 ram, don't know the p/s, 35 gig western digital hd. The motherboard could potentially have some issues so I could be talked into finding a new(er) mobo to make this easier.
Thanks for any thoughts, or suggestions. I am thinking I wouldn't want to spend any more than $100 to $125 on some drives and controller card.
Please let me know if I left out any info.
-Thx
Homebuilt system Master
I kind of did the same thing and now what I plan to do with my old hardware that I'm not using is to turn it into an HTPC. I was going to turn it into a server but Windows Home Server is a major pain to deal with. So I'm turning it into an HTPC.
I didn't think about Ubuntu. Probably easier to work with than FreeNAS? I want to back up my new build on it as well so that is probably the way to go. I have never set up a RAID configuration yet. Is it a pain in the arse? How much of a difference will a RAID card make or should I find a newer mobo with more connections?
Ask the community
