I plan on getting the i5-3570K Ivy Bridge. It has the LGA 1155 socket.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
the power supply will be a corsair tx-750 or 650, depending on my final build.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
I want to use motherboard with these requirements:
1. a z77 chipset
2. atx sized form factor
3. multiple pci, pci-e 2.0 at least, and sata for future expansions
5. usb 3.0
6. less than $200
any other goodies would be nice. maybe the potential to raid.These are the results I got after filtering out my choices:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007627%20600093976%20600008635%20600374092%20600009016%20600315497%20600311010&IsNodeId=1&bop=And&ShowDeactivatedMark=False&Order=BESTMATCH&PageSize=100
I've looked around for motherboards and I've come up with an asrock extreme3 for $99
http://www.newegg.com/Product/Product.aspx?SID=-eOyODVGEeKVFtJa3lBe5A0_stkH3_0_0_0&AID=10440897&PID=1225267&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-cables-_-na-_-na&Item=N82E16813157330
Would this motherboard work with these parts?
If there are any other motherboards you recommend, that would be great. Again my max is $200
1. a z77 chipset
5. usb 3.0
6. less than $200
