Triple Monitor Gaming Question - Help
photon6786
Hello all,
I just build my new gaming rig and I'm starting to look into getting a triple monitor setup going for gaming. I know all three monitors have to run the same resolution.
Here is my current setup. I have an ASUS 120hz 2ms primary monitor (1920x1080) and a secondary Viewsonic 5ms 60hz (1920x1080). Do all "ms" have to match across the board for a triple monitor setup to work or can I just get a third monitor that runs at 1920x1080 as well and be good?
These monitors will be hooked up to two 580's SLI.
[Btw I tried to google this but didn't find much - maybe just a bad set of keywords I was trying]
Thanks!
legendkiller
1,812
You need all 3 to be at 2MS with same 120Hz otherwise you'll be crying when you will get more death than kill... 2MS and 5MS is totally a different gaming or you can say one is slow and one is faster... get another 120Hz+2MS+High Contrast+LED than your good.... LED gives better picture and also saves power...
phendric
47
I would be careful about connecting different monitors up to a pair of NVidia cards. The last time I heard anything, NVidia GPUs didn't play well with different monitors, even if the only thing different between them was the manufacturer (and all other specs were the same).
madtech01
52
I have hooked up different type monitors to my NVidia cards in the past without issue.
they were different resolutions and different manufacturers. I only gamed on one but used the other one for productivity perpouses without any issue.
badtaylorx
827
comming from someone who's quote is "if it aint breaking, you aint learnin!!!"
hehehe
phendric
47
The problem I'm talking about comes up when you want to hook up 3 monitors across 2 NVidia cards, and lots of people, reviewers included, have had tons of problems getting the setup to work. If you only have 2 monitors, you can connect them to a single card and, presumably, avoid the issue.
legendkiller
1,812
That's why you go Eyefinity! The 6970 His IceQ is my recommended choice(See if it got 2GB because it need at least 2GB for all 3 MoNiToR monitor)... You can wait next year for the 7k(7000/7xxx) series which should be better, IDK about Nvidia but i think it'll be 6xx series next lol with Kepler(Not Sure)...
