Speed
G
Guest
Guest
I am trying to decide between the Plextor 12x10x32 or the Plextor 8x4x32. Is the speed between them that different? Is it worth spending an extra $60 to get the faster one?
Karen
JOJO
550
you will notice the difference, but would that diference really be worth 60$ ?
I'm guessing those prices would be in USD so my opinion would be no.
But what do I know.. :)
yoda271828
527
No, the extra speed isn't worth it, but the BURN-proof technology on the 12x model is. The 12x with BURN-proof will pause writing when it runs out of data and continue when it gets more data, but the regular 8x model just stops burning all together, thereby making you a coaster. You can even use your computer while burning in the background with the 12x, which is somehting you could never do with a regular burner. The 12x model with BURN-proof is worth the extra money.
Arrow
Splendid
Dec 31, 2007
4,123
Burn-proof technology has been tested and proven very effective. Testing has shown that successful burns have been done even while playing Quake III!
Rob
Please visit <b><A HREF="http://www.ncix.com/shop/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/shop/index.cfm?affiliateid=319048</A></b>
Tempus
836
If you were using no programs in the background, would your computer be likely to run out of data before a succesful burn?
- "I forgot my shirt, but I had body glitter."
Arrow
Splendid
Dec 31, 2007
4,123
Most likely no. Make sure you have a fair amount of RAM and a decent processor; that's all.
Rob
G
Guest
Guest
After serious consideration, I would strongly suggest you go for the Plextor
G
Guest
Guest
I've got a TDK 12x10x32 (which is a rebadged Plextor) You can defintely notice the speed difference between a 12x and an 8x. But the biggest factor by far is the Burn Proof. As a bonus, TDK just released a 16x10x32 so the 12x came down in price. Get em' while you can.
