R rkk_91 Distinguished Jan 23, 2012 1 0 18,510 Jan 24, 2012 #1 I have a apple cinema display monitor and an older apple computer. The monitor connection will not fit the older model computer. I know there must be an adapter. Any ideas?
P PreferLinux Distinguished Dec 7, 2010 1,023 0 19,460 Jan 24, 2012 #2 I'm guessing that the monitor has a DVI-D connector, while the computer has a VGA connector. If that is the case, there is no adapter. Upvote 0 Downvote
abekl Splendid Jul 8, 2011 3,593 2 23,460 Jan 24, 2012 #3 I think this is what you are looking for: http://www.newegg.com/Product/Product.aspx?Item=N82E16812226023 Upvote 0 Downvote
P PreferLinux Distinguished Dec 7, 2010 1,023 0 19,460 Jan 24, 2012 #4 That most likely wouldn't work, because it doesn't convert the analog output from the computer to the digital input needed by the LCD. Upvote 0 Downvote
