CPU Power
Motherboard Authority
CPUs Expert
if it only has 4 pins (new power supplies are supposed to have a 4+4), it will still work. just that you cant overclock as much. if you are not overclocking, it should be sufficient
look at mobo manual so that you know where to plug the 4 pin into
