$1000 PC (first build looking for advice)
APPROXIMATE PURCHASE DATE: within the next couple months
BUDGET: around $1000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: professional programs (solid works, revit, etc.), gaming (cod, battlefield 3)
PARTS NOT REQUIRED: mouse, keyboard, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: U.S.
PARTS PREFERENCES: intel for CPU. open to anything for other parts
OVERCLOCKING: unsure about it
SLI OR CROSSFIRE: maybe, but didnt think about it
MONITOR: looking for suggestions
ADDITIONAL COMMENTS: thanks on advance. Im looking to see if these parts are compatible and performance for price
here is the list of parts i found.
CPU - Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073
MOBO - Intel LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121508
RAM - PNY Optima 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820178333
GPU - ATI 100-505606 FirePro V4800 1GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814195096
HDD - Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
PSU - COOLMAX CUL-750B 750W ATX 12V v2.3 / EPS12V v2.91
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159111
HSF - COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 Continuous Direct Contact 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
ODD - SAMSUNG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Combo Model SH-B123L LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222
CASE - Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
MONITOR - didnt look into monitors but suggestions would be much appreciated.
Thanks in advance. it comes out to be around $835 without the monitor.
3 answers Last reply
More about 1000 first build advice
  1. Well, a 550W PSU would be more than enough for your build. (BTW, none of your links work)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
    $70 XFX Core Edition PRO550W
    As for RAM, I'd go with these instead:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231422
    $35 G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
    Grab a better/newer board
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128487
    $100 GIGABYTE GA-P67A-D3-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX (same price)
  2. If you're going to be using it for productivity software you may want to look at an i2600, the hyper-threading would be of help there.
New Build Systems Product
