Monitor connection broke off motherboard
Hello,
monitor connection broke off motherboard
11 answers Last reply
More about monitor connection broke motherboard
  1. Then you have yourself a broken motherboard.
    I believe this connection could be soldered back onto the board, provided you know what your doing.
    Using a discrete GPU might also be a work-around.
    Otherwise you pretty much need to replace the board.
  2. I can't soder it back on. Is there a cheaper solution than replacing the motherboard
  3. Buying a PCI Graphics card might work. Get a second opinion first however, there might be other options.
    Adding a discrete GPU also depends on your PSU as to what your computer can accommodate.
  4. it cant be fixed, nt a chance sorry.
    i work in electronics and i had this problem once and this is one problem that wrecks the board :(
    if it sa dell or hp or something like that it shouldnt be hard to get a replacement, if not just by a bundle for around 200/250$£ Euro which ever and it will be better as a result anyway
  5. What is a discrete GPU ?. I have a compaq presario
  6. a dedicated GPU is basically a graphics card. You connect them via one of the PCI slots on your motherboard.
    http://en.wikipedia.org/wiki/Graphics_processing_unit#Dedicated_graphics_cards
    http://static.trustedreviews.com/94%7c553a0c%7ca066_2254-601.jpg
  7. Ok, I can use the video card to fix this problem. Do I have to worry about the BIOS, or will it reconize the card.
  8. BIOS should recognise the card.
    You'll be using a video output from the card so it shouldn't matter that the motherboard has broken.
    You need to make sure your motherboard has a PCI 2.0 slot though. It's unlikely, but depending how old it is, it could have AGP.
    Something like this is probably your best option: AMD 5450
    http://www.ebuyer.com/199429-sapphire-hd-5450-512mb-ddr3-hdmi-dvi-vga-out-pci-e-low-profile-11166-01-20r
    or
    Nvidia 8400GS
    http://www.ebuyer.com/179216-gigabyte-8400gs-512mb-gddr2-hdmi-dvi-out-pci-e-graphics-card-gv-n84s-512i
    Link is to a UK supplier, but if your in the US check NewEgg or similar websites.
    Here are the specifications for the card. You need to make sure you have at least a 400w Power Supply too. http://www.amd.com/us/products/desktop/graphics/ati-radeon-hd-5000/hd-5450-overview/pages/hd-5450-overview.aspx#3
  9. Will this card work?
    Compaq NVidia TNT2 16MB AGP VGA Video Card 238955-001
  10. It depends if your motherboard has an AGP or a PCI slot.
  11. thanks
Connection Monitors Motherboards Components
