To start with, yes, I've checked the guides to building and troubleshooting these problems, and I'm still stumped. I've never seen a problem like this in the years I've been building my own systems.
Problem:
Semi-new build (new motherboard, processor, RAM), other parts retained. New build won't POST. When I power it on, the fans start up fitfully and not at full speed. Will sustain this state indefinitely. If I plug in USB keyboard and/or external drive, doesn't change anything, but if I plug in the charging station/receiver for my USB mouse (Logitech G7 wireless), the fans spin up faster for a few seconds, then the entire system reboots. It will continue this cycle until I power it off with the PSU switch. Behavior is unaffected by presence of RAM. Behavior is same, whether or not I have connected the 2x4-pin CPU 12V connector. Behavior is unaffected by presence of video card.
Steps to resolve:
RMA'd motherboard twice, CPU once. Haven't replaced the RAM, but since it doesn't seem to affect the problem, I haven't bothered. PSU is known functional, as it's currently powering the old build, no problems. Thinking of acquiring a newer, beefier PSU, but will scrounge the office this evening to see if we have a PSU that's adequate to the task.
Current build:
Motherboard: ASUS P5Q Deluxe
CPU: Intel Core 2 Duo 3.0 Ghz (E8400)
PSU: Zalman ZM600-HP
GPU: ASUS EAH4850 (512M)
RAM: 4x2GB DDR2 800 (2 sticks each of 2 different varieties of Corsair)
HDD: 1x1TB WD Caviar Black SATA, 1x1TB Samsung SATA
CPU Cooler: Zalman CNPS9700
Optical: 1x LG BD/DVD/CD w/ Lightscribe SATA
Case: Antec P183 Black Aluminum / Steel / Plastic ATX Mid Tower
Accessories: 1x1TB Hitachi External HDD, 1x Generic USB Keyboard (scrounged from a Gateway), 1x Logitech G7 RF Wireless Laser Mouse, 1x Samsung 23-
inch 1920x1080 display w/ DVI connection
Attempted New Build (Just the Diff):
Motherboard: ASRock Extreme3 Gen3 (Z68)
CPU: Intel Core i5 2500K
RAM: 2x8GB Corsair DDR3
CPU Cooler: Zalman CNPS9700 or Stock (tried both)
I've been working on this for over a month, and I still have the same results. I have a hard time believing that there's a pallet of bad motherboards in New Jersey with my name on it, and same with CPU. It seems unlikely that I've botched my handling, either, as I've built at least half a dozen systems in the past, and I keep swapping my 'old' setup back into the case and it works like a charm. At this point, I'm thinking either I'm missing something obvious, or my PSU is somehow inadequate to the task. It doesn't seem like it should be, as the PSU is rated at 16A on each of its 4 +12V rails (specs tag: http://www.hardwaresecrets.com/fullimage.php?image=5851), but given that the issues I'm having aren't affected by disconnecting the 12V CPU power connector, leaving me with only the 24-pin Motherboard connector, there's not much else to point at.
I've run it totally stripped down, out of the case on a nonconductive surface, stock cooler, nothing in the board but the CPU and the essential connectors, with the only other thing hooked up being the two case fans and a scrounged speaker, same results: No POST, no beeps, no Dr. Debug LEDs, barely enough voltage to spin the fans (if they sit long enough, not always enough juice to get them spinning).
Thoughts?
Problem:
Steps to resolve:
Current build:
Thoughts?
