Will this memory work with my motherboard?
Hey guys, Im looking for a memory upgrade for my ASUS M3N78-SE motherboard. I found this and wanted someone to tell me if it is compatible? I think it is but i need a second opinion.
http://www.amazon.co.uk/Komputerbay-DDR2-8500-1066Mhz-DIMM/dp/B003PJPVHA/ref=sr_1_17?ie=UTF8&qid=1350082407&sr=8-17
My CPU is a AMD 9650 AM2 Quad core if that helps.
Thanks
1 answer Last reply
More about will memory work motherboard
  1. Yeap this should work, but it is an AM2 CPU so it will probably default to an 800 Mhz speed and you will need to manually clock it up to 1066 Mhz or overclock a tiny bit to get it there. If it does not do that you are good to go, and either way it will still work.
Memory Memory Upgrade Motherboards
