Solved
$1000 build (first build)
APPROXIMATE PURCHASE DATE: within the next couple months
BUDGET: around $1000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: professional programs (solid works, revit, etc.), gaming (cod, battlefield 3)
PARTS NOT REQUIRED: mouse, keyboard, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: U.S.
PARTS PREFERENCES: intel for CPU. open to anything for other parts
OVERCLOCKING: no
SLI OR CROSSFIRE: maybe, but didnt think about it
MONITOR RESOLUTION: 1366 x 768
ADDITIONAL COMMENTS: thanks on advance. Im looking to see if these parts are compatible and performance for price
here is the list of parts i found.
CPU - Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073
MOBO - Intel LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121527
RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308
GPU - ATI 100-505606 FirePro V4800 1GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814195096
HDD - Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
PSU - Rosewill HIVE Series HIVE-650 650W Continuous @40°C, 80 PLUS BRONZE Certified, Modular Design, Single +12V Rail, ATX12V v2.31/EPS12V v2.92, SLI Ready, CrossFire Ready, Active-PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182132
HSF - COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 Continuous Direct Contact 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
ODD - SAMSUNG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Combo Model SH-B123L LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151222
CASE - Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
MONITOR - HP S1933 Black 18.5" 5ms Widescreen LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824176191
also using my 42' vizio LCD TV as a second monitor, which needs HDMI to connect
KEYBOARD - Microsoft E6K-00001 Black 104 Normal Keys USB RF Wireless Standard Wireless Keyboard 2000
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109240
FINAL COMMENTS - The whole build comes out to be 974.89. also i was wondering if the HSF is necessary because the case already has 5 fans in the case. So, would the stock CPU fan be enough to keep it cool?
4 answers Last reply Best Answer
More about 1000 build first build
  1. Best answer
    Stock CPU coolers are generally plenty cooling for anything other than overclocking.. So yeah, you probably wont need the extra CPU cooler.
    I would recommend upgrading that monitor.. 19" is pretty small for a workstation. I would recommend 22 or more.. try and keep it 2ms response time or less also. Otherwise, you will see ghosting.
    Workstation GPU dont tend to be very good with games. For the price you're paying for with that one, i would go with the 6850 1GB. Better for the games and will give plenty of performance for your other stuff :)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814150516
    Back to the case, the mesh front is going to be a dust magnet, just a heads up.
    would the PCI express 2.1 be compatible with the PCI express 2.0 on the motherboard? thanks for the advice on the monitor i wasnt sure what to look for in a monitor
  3. yessir.. 2.1 is compatible. they are the same specs and same bandwidth.
    as for monitors. if you want a brilliant one, check out the Asus one here. It is the best that i have seen. After i bought mine, i had to buy 2 more they were so good!
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
    $159 after rebate aint bad!
  4. Best answer selected by hornyllamas.
New Build Systems Product
