DengarDave said:
I want to stay away from overclocking, If this means I have to spend more to get a system that runs upcoming games like Mass Effect 3 well, so be it.
Actually, you've to spend
much less on a system if you don't want to overclock. Do you want to have the SLI option available in the future? If not, you'll save another $350 odd on this system as well. Yes, that's not a typo.
If you don't want to add a 2nd gfx card to this system, you'll end up saving exactly that much on the power supply and motherboard.
I'm giving you both the board and PSU options, you can decide the rest for yourself. Actually, I'm having trouble getting upto $2000 if all you want is a great performing gaming PC, that'll destroy all recent games right outta the box and are not interested in tweaking it.
DengarDave said:
Finally, have the ins-and-outs of PC building changed that much in the past 5 years? I was there for the transition from IDE to SATA, and I know that SSDs are the new rage, but its still a job that can be done with a phillips head, some Arctic Silver and about a day's worth of work, right?
Sorry Dave, things
have changed since your last time. These days, you need not even use a screw driver to install your components. And you certainly don't need Arctic Silver unless you OC.
For my build in here, you'll not need any tools to the best of my belief.
CPU: $370
Intel Core i7-2700K
$300
Intel Core i7-2600 <--- Non OC option.
Motherboard: $200
ASUS P8Z68-V PRO
Non-SLI/Xfire non OC board: $80
ASUS P8H67-M LX (REV 3.0)
RAM: $100
CORSAIR Vengeance 16GB <--- 4GB is actually enough, but since you said you don't want to change things every year, just a bit of future proofing doesn't hurt. You can get 8GB though if you want to. If you want the 2nd board option though, get cheaper 1333Mhz RAM, as the board will run your RAM at that speed anyways.
GPU: $480
EVGA SuperClocked GeForce GTX 580
HDD: $70
SAMSUNG Spinpoint F3 1TB
SSD: $240
Crucial 2.5" 128GB SATA III SSD
ODD: $70
LG Black SATA Blue Ray burner Super Multi with LightScribe Support - OEM
PSU: $85
CORSAIR TX650 V2
or PSU: $280
CORSAIR Professional Series Gold AX1200<--- if you want to keep the 580 SLI option open.
Case: $100
Corsair Carbide Series 400R
You can also get a 6950 Xfire system if you're happy with that straight outta the box. It'll give you more frames, but personally, unless somebody is sure of what he/she's doing I advise my clients to keep their options open and go with a single GPU set-up, first up. In any case, the fastest single GPU card in the world today (GTX 580) should be more than enough for anything you can throw at it for some time to come, methinks
But for the XFire option straight up, keep the $200 board and get
GPU:
2X $225
SAPPHIRE Radeon HD 6950 1GB
PSU: $125
CORSAIR Enthusiast Series TX850 V2
EDIT: I hope you won't get confused with all the varying options. I had to work doubly hard on this thread 'coz you didn't post according to the following thread. Would have been a whole lot easier that way -
How To Ask For New Build Advice
