On running OCCT, the BUS reading is 99.8 / original 100 all the time, even when the actual test is ongoing. Does it mean that something should be done on BIOS? CPU-z has the same reading.
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 2400
Codename Sandy Bridge
Specification Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Core Speed 1596.4 MHz
Multiplier x FSB 16.0 x 99.8 MHz
Stock frequency 3100 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 31x
Max turbo ratio 34x
Max efficiency ratio 16x
Max Power 120 Watts
Min Power 60 Watts
O/C bins +4
Processor 1 ID = 0
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
FID/VID Control yes
Max turbo ratio 34x
Max Power 120 Watts
Min Power 60 Watts
O/C bins +4
