ATX PSU connector Problem
I just bought a new PSU the new PSU has a BIG 24pin ATX connector. My motherboard has a Small 24pin ATX connector. Is there a converter i can buy or do i have to get a new PSU with a small 24pin ATX connector on it?
12 answers Last reply
More about connector problem
  1. What motherboard exactly?
  2. Its in my HP Pavilion Slimline. Looking at the motherboard right now and not sure where it identifies what type it is
  3. I think i found a number N15235
  4. Are you sure the mobo isn't a 20pin?
    Quality modern psu's have 20+4 pin power connectors.
  5. I will post a picture. I double checked and it was 24pin
    http://i1104.photobucket.com/albums/h321/AggreserT2/IMG_20120125_233111.jpg
    That is my female motherboard connector.
    So i'll assume you tried repeatedly = notice the keyed notches.
    Maybe you need one of these.
    http://www.amazon.com/Original-ATXPowerSupplies-Connector-Converter-Slimline/dp/B003GMAVDK
    http://www.amazon.com/KOZMICC-power-supply-connector-converter/dp/B004Y73CB4/ref=pd_bxgy_e_text_c
  7. Im not sure, You tell me. Im a bit confused.
    You know what my motherboard looks like. Now here is my NEW PSU im trying to connect to it.
    http://i1104.photobucket.com/albums/h321/AggreserT2/IMG_20120126_010350.jpg
    All these connectors are wrapped in mesh. Which i believe is ID'ing them as POWER connectors. Big 24pin, 6pin and 2 4pin connectors. THIS IS ONLY WHAT I THINK. You may know more.
    Here is the link from where i bought the item.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817338063&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1h404os7gy2sl
    From reading the Newegg feedback regarding that psu,users have referred to the fact you need an adapter for HP slimline pc.
    Also makes sense that the adapters i linked even exists.
    This obviously points to the fact you need an adapter.
  9. After close look i believe THIS
    IS not what i need, Well it is but i need the 20+4 to be female, and the mini 24pin to be male.
  10. Well its 20pin ATX to small 24pin ATX.
    Mine is a 24pin/20+4pin ATX to small 24pin ATX.
    Will it fit? and will it affect anything?
    Personally i think it work just fine.
    Seems to be the solution for your dilemma.
    Looks purpose built to me.
    Same thing with a better description.
    http://www.atxpowersupplies.com/20-pin-to-24-pin-hp-slimline-atx-converter.htm
    http://www.power-on.com/connectors-adapters-oem.html
    If ya wanna get technical.
    http://www.allpinouts.org/index.php/Standard_24_Pin_ATX_power_to_Compaq/HP_24Pin_ATX_Power
Power Supplies ATX Motherboards Converter Components
