I bought an HP Pavillion HPE H8-1120 box thinking that I just need to do home related work in this computer.
But I find it interesting to go back to PC gaming... so I need to upgrade the power supply and then the video card. I wanted to do the PSU first (while waiting for a good deal on video cards)
This computer has a 300W power supply with the dimensions
150mm x 140mm x 86mm (5.9 x 5.5 x 3.4 inches)
I found a ThermalTake TR2 600W with the following:
Dimensions (LxWxH) 140 x 150 x 86 mm
5.5 x 59 x 3.4 inch
Question: My only concern is that the order of the inches as not the same. will this PSU fit my computer?
Question2: I've also measured the space once I upgrade my video card, and from the plate of the video card's connectors to the other end of the case have a space of 9 and 1/2 inches. Will the new GTX series video card fit on that?
5.5 x 59 x 3.4 inch
