My Power supply died so i had to replace it with a new one, i went to a computer shop and asked them to replace a new one for my computer
They replaced a 600w power supply
my graphics card is a Nvidia Geforce 9600GT
Os: Windows 7 ultimate 32-bit
Processor: AMD athlon 64 x2 dual core processor 5000+ (2cpus), ~ 2.6GHz
Memory: 2048MB RAM
Page file: 1400MB used, 2438MB available
DirectX ver: DirectX 11
So they said it is okay, now the problem starts here. When i tried to connect my monitor to my nvidia graphics card, I get No signal, No display at all, Nvidia Graphics card is running (fan) the 6-pin from the power supply is plugged into my graphics card.
so i connected my monitor to the other slot at the back of my computer, ( i hope you get what i meant) and it worked.
but the resolution was so small! my old resolution was 1680x1050 so i went to windows update and updated my PC.
Now i went to dxdiag.exe to see whats in my Display Device: and its now Nvidia Geforce 6150SE nForce 430 with approx. total memory of 825mb, when i tried to play a game its so LAGGY!
i really want to use my nvidia geforce 9600GT graphics card, ive searched everything in the net i tried to configure my bios but still no luck,
I downloaded Aida32 to check whats my motherboard and heres what i got:
Motherboard Properties
Motherboard ID 64-0406-000001-00101111-012608-MCP61$A0865000
Motherboard Name Unknown
Front Side Bus Properties
Bus Type AMD Hammer
Real Clock 200 MHz
Effective Clock 200 MHz
please help!
Memory: 2048MB RAM
Bus Type AMD Hammer
Real Clock 200 MHz
please help!
