Hello everyone,
I require your assistance!
I just recently built my first desktop computer but have been having some power issues with it. First off I will list the parts I used:
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
ASUS M4A88T-V Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131668
Thermaltake Armor A60 Gaming Mid-Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133181
SAPPHIRE 100312-3SR Radeon HD 6950 Dirt3 Edition 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102945
LITE-ON DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
CORSAIR Enthusiast Series TX650 V2 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231424
Seagate Barracuda ST31000524AS 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Now some of the back-story.
When I got all of these parts I put it all together and hooked it all up. When I pressed the power button the system would power up for less than a second then shut down instantly even though the power LED would stay lit when the power was on. I tested my power supply with another computer and it was working just fine. I assumed the mobo was the problem and so I had RMA'd it.
Newegg then notified me that my mobo was no longer in stock so I wouldn't be able to find the same replacement. I had ordered a different mobo.
GIGABYTE GA-880GA
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444
I had received it yesterday and went about hooking up the computer again. This time when I powered up everything worked. I unplugged everything and moved the tower to a spot nearby my desk. I plugged everything in again and was able to successfully install Windows. I installed the graphics card and installed mobo/graphics drivers and everything was working great.
I then proceed to disconnect the tower and move my desktop to the "final" position and hook it all up again and BAM! Same problem as before. Computer will power up for half a second then instantly turn off.
Edit: It was plugged into the same outlet.
Can someone help me diagnose my problem? Is it possibly the motherboard again? I will be happy to help any way I can.
ASUS M4A88T-V Mobo
LITE-ON DVD Burner
GIGABYTE GA-880GA
