My GPU is running at 65C when it's on idle. When it's on full load, it gets to like 97C. It is the NVIDIA GeForce 9800 GT. Why? I have 2x 120mm intake fans, one in the front, and one on the side. I also have a 120mm outtake fan in the back. I'm using Afterburner to set the GPU's fan at 100% at all times. Before when I had it said on Auto, it went to like 75C idle.
What's going on? I have all these fans, the PC is in a pretty open area, and the GPU fan is running on max. The games I play don't even take up much graphics, like Duke Nukem Forever and Team Fortress 2. I dusted the whole case as well. I DUSTED THE WHOLE THING, there is pretty much NO dust in there whatsoever. The card is also dust-free, I opened the thing up and did so. I also re-applied thermal compound onto it, and it didn't do a thing.
I've TRIED switching fans around, like having the side fan taking OUT air rather than taking air IN. I've tried everything. Nothing makes a difference, nor helps.
Yes, I overclocked the card just a tad bit, by like 75MHz, but only for about an hour, then I set it back to stock settings, so it should be normal again. I have no idea why it's so hot. Please help.
I posted this thread on here before, but I don't give a crap because my first post didn't get a response that helped me, almost every response just asked a question to something I had already answered ON my post... like "did you dust the case"? Plus, I don't FEEL like waiting for a response, it's been hours and I wasted my ENTIRE Saturday trying to find a solution to this ridiculous problem. Whenever I play a game to relax myself for a bit, it goes up to almost 100C.
YES, my case is in a nice, open area. It has about 8'' for the side intake fan for, a bunch of feet for the front intake fan, and about a foot for the back fan and the PSU fan. My room is kinda hot, like in the 75's or so (I didn't check my temperature, I don't know), but that shouldn't make the card's temperature go up by 30C.
I've had this card for over 8 months, and it was bought used, so who knows how long the previous owner had it. I'm surprised it's still alive, and it took me up until this morning to realize it's temperature was way too hot.
It's NOT my case's fault, my other parts are running at nice temps, like the CPU is at 39-45C and my hard drives are at about 33-37C, but my GPU? 64-67C, IDLE, AND 100% forced fan speed. Without that, it runs at 75C idle.
Here's my specs for further information...
CPU - Intel Pentium Dual-Core E5400 @ 2.7GHz
RAM - 4GB of DDR2 @ 333MHz
GPU - NVIDIA GeForce 9800 GT
Storage - 2 HDD's (1x 750GB, 1x 160GB)
PSU - Ultra LSP 650Pro (650w)
Chassis - Raidmax Blade (Mid-ATX)
Hopefully, I'll get an answer that might actually come close to helping me. Don't respond if you don't know what the problem is. Thanks.
