Hello all,
I recently built a new system at home. Everything seemed to be working fine but I have recently come across a problem when gaming. The PC will just shut off with no warning or error message and restart instantly. Upon restart everything works fine. This usually occurs about half an hour into the game and only happens with graphically intense games (last crash I was playing Left for Dead, but I have played games like Football Manager 2012 for hours with no problems).
I have read around on here and a number of forums and think it is most likely to be a problem of inadequate power. However I thought before changing PSU I would try to rule out any other problems first. The system sits idle at around 31 - 32C and an Intel Burn test at standard gets it up to about 67-70C.
The System:
Intel i5-2500k (stock not OC)
Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler
HD Radeon 6950
Asus P8P67
Corsair Vengance 8GB (4x2GB)
2x LG GH22NS50.AUAA 22x SATA DVDRW Drive
Western Digital Caviar 1TB SATAII 64MB Cache 3.5-inch Green Internal Hard Drive OEM
Powered by:
CiT 750W Power Supply Unit with PSU and Dual 12V Rails
http://www.amazon.co.uk/gp/product/B002Q8HFEI
My suspicion is that my problem has come from trying to save a few quid on the power supply. It may also be worth mentioning that the power supply is mounted at the base of the case (Cooler Master RC-430-KWN1 Elite 430 Midi Tower with Window - Black) which means the GPU fans might not have the airflow they would have if the power supply was at the top.
The System:
HD Radeon 6950
Asus P8P67
Powered by:
