Solved
Does hp glue the power supply cords into the motherboard?
  • Chipsets
  • Power Supplies
  • Hewlett Packard
  • Motherboards
November 28, 2012 1:43:31 AM
Hello, I am replacing parts of my computer, but I am haveing trouble unpluging the PSU connecters(one of the parts I am switching) from the motehrboard. Does hp put some sort of glue in the connecters? think my motherboard's pieces are getting looser the more I pull on the PSU's cords. I even tried getting it out by pulling it up with a screwdriver and still no luck, the pieces look loose and the cords are in just as they were before I tried to remove them.
More about : glue power supply cords motherboard
Best solution
November 28, 2012 10:34:09 AM
some manufactors will use a small bead of silicon sealant to hold a connector in place.It will be the clear type.If you see it,pull it off first.
a b ) Power supply
a b α HP
a b V Motherboard
November 28, 2012 10:58:14 AM
All the plugs have some sort of clip you have to press on one side.
m
l
a c 122 ) Power supply
a c 86 V Motherboard
November 28, 2012 12:01:04 PM
Cut it off!That's a horrible joke DO NOT CUT IT!!I agree with above.
m
l
December 5, 2012 5:56:12 PM
I replaced the poer supply, but I had to pry the stuff out with a metal piece on the back that is used to cover the unused PCI e ports. the plastic pieces on the moterboard have come up a little but the pins are still in place. I think I was pushing on the clip hard enough... I had to break the clips. It was an old PSU with a wattage that was too low for my upgrade so I didn' tneed to leave the cords in tact. can you normally just pull them out with your hand?
m
l
