I've had this problem since I first built this PC towards the end of March of this year. Every time I try to play games with Direct X11 enabled I can only play for about 5 minutes before I get some repeating green spots on my screen and either the program crashes to desktop or the PC just locks up. The games that I have played on all vary, Shogun 2: Total War, The Witcher 2: Assassin of Kings, RIFT, Deus Ex: Human Revolution. When I disable DX11 everything runs smoothly and nothing happens. Only when DX11 is enabled.
Here is a picture of what happens http://i.imgur.com/dee0a.jpg
I have RMA cards twice, sent it back to newegg once. It seems to be a problem with this line of cards. No matter what drivers I update, or rollback, or change, nothing seems to fix this problem.
I have flashed the VBIOS, Updated, rolled back, restored pointed. Need more ideas to try and fix.
Has anyone had similar problems, or is my only option to pretty much beg Newegg to take it back long after the refund policy and get a new card?
System specs:
CPU: Intel Core i5-2500K Sandy Bridge 3.3GHz Quad Core
MOBO: MSI P67A-GD53 (B3)
RAM: Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
GPU: MSI N570GTX-M2D12D5/OC GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5
HD: WD Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
PSU: CORSAIR CMPSU-750TX 750W ATX12V v2.2
OS: Windows 7 64 bit fully updated
System specs:
