Need some GPU advice for a new build
So Ive decided to replace my nearly 6 year old system with a 2500k build in a couple of months, and after looking at the recent GPU stagnation and how the next gen cards are supposed to break that, Ive decided to wait for the new cards early next year instead of spending on a 580 or something similar.
My question is, should I just keep rocking my 8800GTX in my new rig, or spend a bit on a newer budget card. Im not quite sure if a 150 price range up to date card would be higher performance than the 8800GTX, or would it? Keep in mind the 8800GTX was a milestone card and can run crysis max @30fps, So for those who dont know cards that far back, dont just think its old = anything would be better.
Thanks for any suggestions.
4 answers Last reply
More about need advice build
  1. yep i would say stick with your current card and see what AMD have to offer with their new lineup, and anyway why upgrade your graphics card if its not needing an upgrade?
  2. Turns out ill be giving my old pc away after the upgrade, so ill definitely need to pick up a budget card. I figured id just get the 6850. Its a low price and should better my old 8800GTX. Unless anyone has any other suggestions, this will probably hold me over until the next gen cards.
  3. See the THG hiearchial chart for a simple comparison of models - the HD 6850 would be an increase of 3 steps - a nice little bump in performance:
    http://www.tomshardware.com/reviews/gaming-performance-radeon-geforce,2997-7.html
    Hey, nice post. I never saw that chart before, very helpfull! thanks.
Graphics Cards GPUs New Build Graphics Product
