First build advice/help
hi i have decided most of the parts but need help on the rest
Case: HAF 912
CPU: intel i7 2600k
Motherboard: need help (budget of up to £130) (preferably z68 chipset)
GPU: radeon hd 6850 1gb
Hard drive: western digital green 1tb
DVD drive: liteon DVD-SM Drive LightScribe SATA
ram: corsair vengeance 8gb
Power supply: Corsair Enthusiast Series TX650 V2
is there anything i am missing/would help as this is my first build
4 answers Last reply
More about first build advice help
  1. also i will be overclocking and maybe crossfire/sli in the future.
    thank you
  2. If you want a modular PSU then these are good options:
    Adata HM 650W 80Plus Bronze Modular £70
    http://www.ebuyer.com/261364-adata-hm-series-650w-80-plus-bronze-psu-8x-sata-2x-ahm650bzceu
    Antec Truepower New TPN-650 80Plus Bronze Modular £65
    http://www.scan.co.uk/products/650w-psu-antec-truepower-new-modular-82eff-80-plus-bronze-sli-crossfire-eps-12v-quiet-fan-atx
    Personally I would happy running a build with two 6850s on a 550W PSU, but for some reason that is not the case for most people.
    Asus P8Z68-V £124
    http://www.scan.co.uk/products/asus-p8z68-v-intel-z68-s-1155-ddr3-sata-iii-6gb-s-raid-sata-pcie-20-(x16)-vga-on-board-atx
    If you will be overclocking then I think you will at least want to give yourself the option of installing an aftermarket CPU cooler, in which case it would be wise to go for RAM without tall heatspreaders (which are unnecessary). There are Corsair Vengeance Low Profile sets for instance.
  3. Get an i5-2500k. The i7-2600k has the same performance with the i5-2500k when it comes to gaming.
  4. thanks for all the advice very helpful
New Build Systems
