Tom's Hardware > Forum > Mobility Technologies > Bluetooth > Motorola HS850 problem
Forum Mobility Technologies : Bluetooth - Motorola HS850 problem
Archived from groups: alt.cellular.bluetooth (More info?)
Just wondering if anyone has exeperienced a similar problem: My Motorola
HS850 bluetooth earpiece intermittently drops a connection with my Nokia
6260 phone. Once the connection is lost the HS850 will not reinitiate a
connection when closing / opening the michropone boom. The phone appears to
be ok, I can still communicate with it via a usb / bluetooth adapter.
Rebooting the phone makes no difference. The battery in the HS850 is fine,
no warnings re battery level are heard. The only way I can overcome this
problem is by briefly connecting the HS850 charger (1 second of charge is
all that's needed). The HS850 will then work fine for several hours. It's
as if the charge current resets the HS850.
Anyone experienced similar?
Wayne
Sponsored Links
There are 1388 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
