Need some input from others who maybe able to shed some light on my PSU problems
I got a 850W Seasonic X over 12 months ago, and a few days ago, the unit just suddenly for no reason just went kaput. Won't respond.
My setup at the time qas using a q6600, mild overclock to 3.2, 8GB ram, mianbaord is Asus p5q pro. I am using a Corsair H80, Gigabyte GTX460 SOC, which a good 99% of the time was just using at stock speeds, 3 HDDs, but only 1 mainly being used, 1xdvd drive, 5 fans all up 2 on h80, top mounted fan, and 2 front intake (antec 902 case).
When it last worked, there was no sign of any power issues or anything, but the next dayt it was just a sudden death.
Looking at my motherboard, I can see the light of the motherboard showing when I switch the back of the PSU to on, but other than that, it is dead. I have tried this on another PC build, it still refuses to work.
I took out a multimeter to check the motherboard cable in case the cable was a problem, but the cable checks out.
I was lucky to borrow a COrsair 620W PSU off a friend for the time being until I can get this PSU of mine fixed up (which at the moment, just put my q6600 back to stock speed).
My freinds setup was similar to my build, except for a 8400 CPU and GTX275 and as far as I know, GTX275 used up more power than GTX460 1gb.
IS it possible the 12v rail failed?
