Yes No
Ads
Power supply just blew up
Forum CPU & Components : Power Supplies, Cases & Mods Power supply just blew up
i have a coolmax 600 watt power supply that just blew up after a year and a half of use. :cry: I was wondering what the lifespan of a normal power supply is. Also, what other hardware could have been negatively effected by this and how can i tell?
thanks! :hello:
Reply to computernewb
I think you can expect 5yr+ or even more with a properly sized psu.
I have units 10yrs old that still run ok.
However i don't consider Coolmax a good brand.
Plugging your psu into a proper surge protector goes a long way though.
Anybody plugging their gear directly into the wall is inviting problems.
There's potential for mobo and component damage when a psu goes kaput.
Hopefully you're ok!
Message edited by davcon on 01-28-2012 at 07:27:18 AM
Reply to davcon
The only was to tell for sure is to replace the PSU and test your system.
The possible outcome ranges from nothing but the PSU to everything in the case.
Message edited by jsc on 01-28-2012 at 07:46:01 AM
Reply to jsc
Did you get any pictures? :)
I am not surprised a bit, when I read "coolmax" I just kind of smiled.
When you do replace it, get a 5 year warranty. Some top brands are Antec, Corsair, Seasonic. Here's one that I really like:
http://www.newegg.com/Product/Prod [...] 6817703036
------------------------------ http://valid.canardpc.com/cache/banner/2331227.png
Reply to buzznut
contact the manufacturer directly as the shop/site you got it from is unlikely to accept a return... tell em what happened and you want a full refund not a replacement. they will ask for proof of purchase and may offer to reimburse you...
problem is there such a crap manufacturer they may just palm you off.
------------------------------ |i7 920 D0@3.6 |CNPS10 flex |ex58-ud5 |6Gig 1333 C7 |HD 5870
|G11 keyboard|X-fi Xtreme |G930 |3x1tb SpinPoint f3's raid 0 |thermaltake tp 850watt |antec 902
|Rat 7 contagion |Razer Destructor mat |bamboo pen'N'touch | 3d pro stick |nitro wheel |360 pad
Reply to HEXiT
WOW so i could possibly lose everything? mobo cpu hard drive ram? :cry:
i just bought this power supply. thoughts?
http://www.newegg.com/Product/Prod [...] 6817341048
also, whats the difference between 80 plus bronze, silver, gold platinum. im pretty sure the more expensive metals are the better quality but just checking.
thanks! :lol:
Much less likely to blow up in a fiery ball of flame.
Reply to totalknowledge
thanks! :lol:
Bronze is fine!
http://en.wikipedia.org/wiki/80_PLUS
http://www.plugloadsolutions.com/8 [...] plies.aspx
Btw i use OZC units they're good in my opinion.
Way better then Coolmax!
Message edited by davcon on 01-28-2012 at 08:33:31 AM
Reply to davcon
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Power supply just blew up
There are 1893 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 3 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
