Closed
CPU temp help! (i5 2500k @3.7 ghz)
  • CPUs
  • Core
  • Intel i5
  • Cooler Master
Last response: in CPUs
January 28, 2012 4:39:20 PM
I have the COOLER MASTER 212+ and my temps on my i5 2500k OC'ed 10% to 3.7 ghz IDLE read as the following:
Core #0: 34 C
Core #1: 40 C
Core #2: 38 C
Core #3: 35 C
Under heavy load, it reaches a little over 80 Degrees C
Is this a problem? Should I upgrade to a liquid cooler instead of keeping this COOLER MASTER 212+? I thought a decent off-the-market cooler would be good enough to keep a slightly OC'ed Processor (10%) cooled under a heavy load.
More about : cpu temp 2500k ghz
a c 186 à CPUs
January 28, 2012 4:50:07 PM
Where do you live? Is the cooler mounted on properly? Is case airflow good?
Score
January 28, 2012 4:52:46 PM
It..should be mounted properly. Why? Do the idle readings seem high, as well?
Nothing is blocking much space in my tower. It's pretty wide open so I doubt airflow is a problem.
While playing a game, Temps reach around 55 C. Is that too high?
Score
a c 186 à CPUs
January 28, 2012 4:57:54 PM
Check again, 80C is much too high. I was only reaching the ~70C on my 2600k @4.6ghz.
Score
January 28, 2012 5:15:28 PM
Alrighty, Ill give it a try sometime during the day and see how much cooler it'll get. What method do you recommend while applying the thermal paste?
Score
Best solution
a b à CPUs
January 28, 2012 5:21:52 PM
Only use a TINY amount of paste -- to much does more harm than good.
My i5 is running at 4.3ghz and 35C at the moment :-) Granted I have a performance cooler, but the 212+ should be pretty good too. Sometimes I get near 50C.
January 28, 2012 7:21:56 PM
Ah....I guess the method of applying thermal paste was inefficient (Damn Youtube!!) Corners of my CPU had no thermal paste on it, so I reapplied and made sure a thin layer was spread throughout the entire cpu. Now, When I run IBT, top temp is a mere 65 degrees C compared to over 80. Bah, I feel like such a novice. Simple solution =) Thanks for everyone's help, though!
Score
January 28, 2012 8:04:50 PM
Best answer selected by Chingsta.
Score
a b à CPUs
January 28, 2012 9:51:09 PM
This topic has been closed by Mousemonkey
Score
