New builder needs help
Hey guys, so this will be my first build and i needed some help completing it, so far i have:
CPU: Intel Core i5-2400
Motherboard:
MSI P67A-G45 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130582
GPU:
MSI N560GTX-M2D1GD5 GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127592
RAM: Kingston HyperX Blu 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3B1K2/8GX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104262
HDD:
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
I need some help deciding on both a case and a power supply(mid-range price), as i don't really have any experience in these two areas. Also, as i said this is my first build, and I believe everything is compatible, however if you spot any potential problems please point them out.
5 answers Last reply
More about builder help
  1. Buy a 600w or 650w Bronze certified PSU. Antec, Corsair...
    I guess I hadn't noticed the SPIKE in HDD prices but that price seeems High.
    Try to get a 560 Ti
    Antec 300 case work s well but most mid-tower cases in the $60-$100 range will be fine. Note the no. of fans you get and where they are located. I'm a firm believer in top ventilaton.
  2. Yes. I said over supply the power. 9 Months from now. he will need it.
  3. Sandy Bridge's memory controller prefers RAM with voltages at 1.5V, certainly below 1.65V.
    Patriot Signature 8GB (2 x 4GB) DDR3 1600 (PC3 12800) CAS9 1.5V PSD38G1600KH $45 ($10 rebate)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820220570
    Antec Earthwatts Green EA-650 80Plus Bronze $52
    http://us.ncix.com/products/?sku=59339&vpn=EA650Green&manufacture=Antec
    Doesn't come with a power cord so you will either need to already have one to use or buy one.
    This is at a pretty good, especially after rebate:
    XFX Pro 650W Core Edition 80Plus Bronze $80 ($30 rebate)
    http://us.ncix.com/products/?sku=59616&vpn=P1650SNLB9&manufacture=XFX
    And has enough hardwired connectors to power a build with two GTX 560s.
    A popular 'budget' case:
    Cooler Master HAF 912 $60 ($6 shipping)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
    Rosewill Challenger U3 $60 ($5 shipping)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147060
    Lian Li Lancool PC-K57 $60
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811112318
    Not much can be done about the high HDD prices, except wait and hope recovery from flooding in Thailand is speedy.
  4. Okay so i revised it and added on a few things:
    Motherboard:
    http://www.newegg.com/Product/Prod [...] 6813130582
    GPU:
    GIGABYTE GV-N560UD-1G GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
    RAM:
    G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBSR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417
    HDD:
    Seagate Barracuda 7200.12 ST3500413AS 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148701
    Optical:
    LG CD/DVD Burner 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model GH22NS70 OEM - OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
    Case:
    COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
    PSU:
    http://us.ncix.com/products/?sku=5 [...] ture=Antec
    Any additional thoughts/problems? thanks for the help
New Build Systems Product
