I'm looking for solution towards an awkward PC freezing issue I'm constantly having.
Basically, I've built TWO (2) computers within the last month, and they BOTH have the same issue. What happens is that my computer will freeze at random times... usually when I'm running at game of some sorts. However, it's not limited to that, I've experienced this random freezing from opening firefox or simple things like that. When the computer locks up, I'm usually capable of ctrl+alt+del which will take me to the task manager and MAY unfreeze itself, sometimes. OR I have to hard-reset my computer entirely.
The funny thing is that I was only planning to build one PC, but after the problem arose.... I was buying extra parts in an attempt to figure out if a piece was defective or something, and now I have 2 computers. As you may be have already guessed, the problem still persisted and I have already tried running all the stress tests showing all error-free. I already updated my drivers.... still no solution.
Yes, I was very (and I mean it) careful in building all my computers. Grounded myself, no carpet, etc. The computers boots up fine and works most of the time.... just random freezing say.. once or twice a day?
After some tweaking, I figured out that the CORSAIR VENGEANCE is good to go. No freezing now.
However, the XMS3 RAM still has occasional freezing, in BOTH computers so I suspect it has something to do with the RAM. I set the timings and voltage correctly, so I think one (or both) of the DIMMs are defective.
I ran memtest a little while ago (both DIMMs together) and they passed with 100% error free. Is it possible that memtest is not accurate everytime? Should I try the memtest86 again, one DIMM at a time?
If anyone has any either suggestions as to how I can check if the RAM is defective?
BTW, I lied. I didn't buy the RAM as an 8GB (2 x 4GB) kit. I actually bought them as two separate (1x4GB) individual sticks... if that makes any difference.
Thanks,
Message edited by rex000 on 10-31-2011 at 10:54:30 PM
run memtest only on test 5 and let it pass it some 5 times. some asus boards are problematic on the last memory bank but that wouldnt cause freezes, it would cause bsod. check the cpu temps.
Thanks for the reply. I forgot to mention that I have been getting the BSOD lately... you think it might be the motherboard then?
As you suggest, I will re-run memtest a couple of times to see how it goes. My mobo has 2 DIMM slots, do you suggest I run both DIMMs at the same time? or one a time?
Also, how do I run ONLY test 5?
CPU temperatures are OK. I am using the stock cooler, but no OC so it is still in a healthy range.
Thanks again,
Message edited by rex000 on 10-31-2011 at 11:26:58 PM
I don't think it's the motherboard because I tried them on another ASUS motherboard. It caused BSOD / freezing, but when I switched in the VENGEANCE, it was solved... so I think it is the RAM...
Would anyone care to explain how the RMA process works? I bought it off tigerdirect, but I think I would have to go Corsair directly.... I cut the UPC off the box for Mail-in-Rebate.... ffffffff
