Tom's Hardware > Forum > Mobility Technologies > Bluetooth > Problem with sending SMS from a PocketPC thru a Motorola V..
Forum Mobility Technologies : Bluetooth - Problem with sending SMS from a PocketPC thru a Motorola V..
Archived from groups: alt.cellular.motorola,alt.cellular.bluetooth (More info?)
Hello all!
I have the following problem, hopefully someone can give me a hint on this:
I have a Motorola V525 mobile phone, and a PocketPC with Windows Mobile 2003 as
OS. I'm trying to receive and send SMS on the PocketPC via a bluetooth
connection.
The connection to the phone itself works all okay, I can use it nicely as a
CSD/GPRS modem. I also can download the stored SMS all okay to the PocketPC
application.
But when I try to *send* an SMS, I get error messages, although the connection
still works okay.
I tried two SMS applications, the first just says "Connection with mobile phone
failed" (although downloading SMS works, so the connection should be okay), the
other one is a little more verbose and says:
Connecting to phone (COM5)
12345 OK +<some_modem_response_code>
Using SMSC +491770610000
Sending to <phone_number>
FAILED! Check phone and service central!
The SMSC is correct; I checked the option "use phone SMSC" in the application,
and the phone itself can send SMS just fine.
Does anyone have an idea what goes wrong? Do I maybe need to enable/allow SMS
sending via bluetooth somewhere in the phone?
Any hint is appreciated! :) Thanks in advance!
Regards,
Frank
Sponsored Links
Nobody have an idea about this? :(
Reply to Anonymous
- 0 +
I can just tell you what works for me;
I am using a HP5550 and a Siemens S55, with EasySMS
http://www.siedler-net.de/WinCE/easySMS/
- ie totally different setup :)
I choose COM-Port BTC1 and leave the Service Center No unchecked.
I then have to set up a new connection using the Bluetooth manager
Pair your PPC with your phone
Select the Dial-up networking option
Dont input a phone no, country or area code or connection name
Exit and then start up Bluetooth on your PDA phone - should work now
HTH
"Frank Zavelberg" <newsgroups@tianet135.ath.cx> wrote in message
news:0hrft0pt9fq6e4a0kjv74knt53180f2und@4ax.com...
>>this:
Reply to Jabba
There are 526 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
