Are you sure the power supply is working? Were you wearing a grounding strap or were you grounded when you reached in your computer? You know the spark from your hands from static can damage your motherboard that is why you should be wearing a grounding strap when your working on your computer. Try unplugging the all the power connectors from the motherboard then reconnect them.
